- Apr 5, 2018
- 105
Well that's hopeful then, thanks David.
Thanks! I'm leaning toward the KC-20VS because most of what I've read is that round column mill/drills can be a real pain to maintain head alignment.
On the other hand, the ability to swing the head can be an advantage as you can put it over any part of the table and still have full travel. I typically have the vise on the left side of the table, and the right side is free for another setup. I couldn't do that with just the X axis travel.Yep the RF-30/31s have alignment issues when moving the head but as you said there's remedies for that. But even without them if you plan your operations out before hand you can avoid moving the head...
