- Feb 17, 2021
- 466
what kind of lathe you using??Harbor freight usually hs decent parts support.
Sent from my SM-G781V using Tapatalk
They quit carrying the 9x20 at least 5yrs ago. Lots of machinery was discontinued. I’ve not even tried them, if they still have parts I’d like to know.Harbor freight usually hs decent parts support.
I have an Emco 9x20, and have had good luck with the parts I've gotten from Grizzly fitting, mostly handles, and fittings. There have been a couple parts that had changed, but even these were mostly adaptable by getting the neighboring part, probably more a matter of age than brand. Over time parts get minor redesigns.
You want to look at the Grizzly G4000. They have a good parts breakdown, and I've found Grizzly's parts dept to be easy to use.
Be aware some of these lathes are metric and some inches, at least so far as the spindle thread. Jet uses a 1-1/2"-8 spindle, the current Grizzly G4000 and many of the other brands use a metric M39 thread. Some older Emco and Grizzly used an inch thread. I do not know what if any impact this will have for other parts.
Grizzly G4000 parts
so your saying grizzly does have parts for that 9x20 correct??^^^ This... mine has the M39X4 threads.... and, as mentioned, Grizzly is a great place to get parts for it as most of them are the same as their G4000
how many change gears should it have??Make sure it has all the change gears for cutting threads if you plan on doing that
Buying them separately could set you back time and money
-M
Correctso your saying grizzly does have parts for that 9x20 correct??
