- Apr 30, 2015
- 11,323
Yep, quite possible. Then you break out the JB weld! Put it in there forever LOL
But yea, insert is best
I prefer your approach in being as least "invasive" as possible. With that, I do have time on my side.A Harley Sportster case. XR, whatever. Easy to screw up, so one of the best tools you have is time. The "Ed's Red" mentioned is good stuff. I would build a wall of sorts around the naughty stud and pour the Ed's Red in. Let it set. Every day or more check it's still covered with the mix and add more as needed.
The idea previously mentioned of cutting the stud off just above the case and welding a nut on to use an impact on is good as that stud will bow as you apply any torque to it by hand or impact. And you don't want to re-use it anyway.
I wouldn't want to snap it off in the case. I've had a big twin case with one snapped off. I'm kind of anal about centering up on broken fasteners, and when I got it ready I still had to hold my tongue right to get the cylinder and head on.
Before you go back together get new headbolts. Probably all of them need replaced.
And yes; I'll shut up now.
Time-sert?Yep, quite possible. Then you break out the JB weld! Put it in there forever LOL
Time-sert?
Type F or Dexron III hasn't changed as far as I know.I’ve had no problems. Maybe that’s with synthetic ATF?
Heli-coils installed properly, have saved many a problem In my experience.Timesert or helicoil. Look at the meat you have to work with after you get the stud out.
True, but inserts being all one unit are the best ticket for things like head studs and spark plugs where strength and being able to change it out in the case of the spark plugs. Seems like a small thing but inserts are stronger IMHO.Heli-coils installed properly, have saved many a problem In my experience.
