- Feb 9, 2017
- 5,249
My experience was with VW cases and studs. It became standard practice to pull the studs and put case savers/threaded inserts in because it was a mess if your fresh rebuild had a head stud pull. I would remove the studs after putting the case in the hot tank. So the combo of heat and solvent along with double nutting with an impact always did the trick. Never had one break. 16 studs a case is really asking for trouble…..dissimilar metal corrosion is horrible dry but seems to give a certain amount of porosity for penetration. Unscrewing it with an impact and not side torquing with say a wrench is important in my mind. YMMV.
