- Feb 10, 2014
- 366
I don't have a picture but years ago I had to machine some foam rubber sleeves. I made an arbor that the sleeves would slide on to with a flat washer and nut on each end. The arbor was chucked on one end and a center in the free end.
I installed the sleeves, brought the nuts up snug and soaked the whole gizmo in water, prior to putting in the freezer. Once frozen, the arbor was set in the lathe and a turning cut with a very sharp carbide insert was made. It took several trips through the water, freezer and lathe, but in the end, the foam sleeves were the correct diameter.
clever, never would have thought about turning frozen foam
