- Sep 22, 2010
- 7,223
My VN #12 milling machine lies in pieces in the tiny shop area of my basement. People are starting to talk. Didn't I hand the board over to Tony to get some work done in the basement? Yesterday was 100 degrees in the basement. But today, only 90. So off I go, to Home Depot with the plans I drew up, to buy some wood and hardware. They don't sell 4x4 pine, so I change my plan, and buy all 2x4 studs, 2-2x10s, some 4" and 7" long 1\2" hex bolts, and 4 right angle joist hangers that take 1/2" bolts, and matching 1/2" washers and nuts. I'm gonna built a temp. wood gantry just big enough to lift the pieces and assemble them together.
Now, you may recall, a previous hair-brain scheme to double the house joists and put in a pipe to attach a come-along to. Didn't like that after all, too many heating and water pipes. Who needs to bust one of those? Or mess with the house joists? So a gantry it is. Self supporting.
Why not just buy the HF gantry? Three reasons- too expensive ($700), too big, and I don't weld. With wood I can scale it down to 5' long, just enough to surround the mill area. Shorter distance, the sturdier it is. The whole materials list was about $50, perhaps a bit more. The maximum load needed to lift is the 500 pound base and column pieces.
Two 2x4s are the posts. They can be made whatever height you want. I kept well clear of water pipes. Want em longer? Make 2 more and bolt those in instead. The design is very flexible.
The sway braces on the sides are not yet attached, but I tried to get some pix on my iphone.
The bridge is made of 2x8s with 2x4 spacers bolted and desk-screwed in. The two posts get bolted into the sides of the bridge.
The posts are attached the the bases with the right angle joist hangers and 1/2" bolts. The sway braces will reinforce this.
On the top, there will be a steel pipe that the come along attaches to. The come-along cable goes down through the bridge to hoist the load. By using two come-alongs, in tandem, one on each side of the pipe, the pipe can be slowly rolled across the bridge to position the load sideways. There is a piece of all-thread that will go through the pipe, and two pieces of 2x8 squares will serve the function of keeping the cables from slipping off the pipe and allow me to roll the pipe more easily.
The side sway braces need to be applied next- that will be tomorrow's job after work.
:tiphat:Nelson :beerdrinkers:
