I’m perplexed as well. I bought mine in 2018 from PM and it’s black with 4 t-slots. If it's important, call PM. At the time I bought mine, Matt had the best prices.
Here is one on eBay where it's specifically 4 slots. The price is about $120 higher than my cost at PM, but it's been almost 2 years, with plenty of new import tarrifs on Chinese goods since then.
Here's one from Acer where the photo shows six slots, and the spec sheet in the same listing shows 3 slots. Go figure.
I don't know your experience using a rotary table, so forgive me if I'm being pedantic. They are time consuming to center, and even more time consuming to center the chuck on the centered rotary table - they all have to be in concentric alignment to the spindle.
This video is a good example of the centering routine and hassle. This is what drove me to make the centering spud shown in the video I linked to above.
I would prefer to have 4 t-slots for tapping the chuck around to get it centered, but I don't think it's critical. I generally center in Y-axis first, snug that down, then center on the X, then re-check the Y. So I think in terms of 4-quadrants like a 4 jaw chuck centering. Having 3 t-slots doesn't prevent that same technique, but it can get confusing if you don't force yourself to ignore the fact that there are only 3 t-slots on the rotary. I suppose there is an argument to be made that 4 slots gives more options for clamping when a chuck is not used. By that logic, 6 would be even better.
The center of the HV-8 is MT3 taper, but it isn't very deep. A standard MT3 arbor is too long and will need to be cut shorter - they are hardened so I used an angle grinder with cut-off disk. That MT3 center can be really handy in mounting things you want to more quickly add/remove. I can imagine a 4" chuck on an MT3 mount being ideal if 4" is a big enough chuck for your work.
This is an example - non-rotating type.
I can confirm that my HV-8 takes
these specific t-nuts. At least the 4-slot version does.
This is the dividing plate system for the HV-8 - they can be hard to source.
Rotagrip in the UK carries a lot of Vertex stuff and I order from them often. They ship promptly to the US at reasonable prices. They also carry the
Royal EasyChange system at prices about half what they are in the US.
If you get to the bottom of the number of slots confusion, I'd be interested in knowing what's up.
BTW, be careful - there are counterfit Vertex rotaries on eBay. The Vertex brand is so much better than the Phase II, it's almost shocking.
