- Dec 2, 2012
- 1,723
I always use a 3 flute for slotting . Only one flute is in contact with the work at any time reducing overcut .
I like the two and three flute cutters for slotting , I never have good luck with a four flute.
Stu
The key to it is overlapping plunge cuts and then taking out the leftover protrusions, and finally offsetting .005-.010 per side to finish up the cleanup.Agreed, the only way to cut an accurate slot is in two passes with a smaller diameter end mill. However, if you don't need high accuracy, slots for bolts etc, I find that a straight cutting, 2 flute end mill or router bit will give the best one pass results I'm not sure why but I heard it long ago and it seems to work.
Wow, this forum never disappoints! Thank you guys for the super informative responses.
So even in steel I should use a two flute cutter for slotting and to cut the slot undersize first...now I know.
Machining is wonderful. I love learning all this stuff. I wish i got into this as a profession.
Ill keep that in mind. Thank you!I like the two and three flute cutters for slotting , I never have good luck with a four flute.
Stu
Thats good to know man. I was thinking of trying plunge cutting but like i said before my endmill wasnt the best. However if I thought to go undersized I could have used a sharper carbide endmill.The key to it is overlapping plunge cuts and then taking out the leftover protrusions, and finally offsetting .005-.010 per side to finish up the cleanup.
That is what I did here and took 1/2 the diameter of the endmill per plunge as it was soft aluminum. For steel I would go more like .100 or less depending on the rigidity of the machine and the depth of cut.
On this cut I was doing little "Exploratory machining" just wanting to break through and not touch (Read gouge) the inner walls of the tube under the plate. For this slot it didn't matter the size it cleaned up at, but using that .500 mill, I could have easily made a .510-.515 slot with clean sides.
If however I wanted to get an on size .500 slot, I would use a 7/16" endmill and math.
I know, sadly, manual machining seems just about dead in terms of industry applications. I was looking into taking a manual machining class at a local boces a couple years back but missed the registration deadline and I thought to myself "that sucks but no biggie ill take it the next semester" next semester it was gone and it was introduction to CNC. CNC is cool but i love the art of manual machining and would love to learn and develop my skills better than just trial and error...mostly error lol
Sounds like you have your head straight. Most guys now want to jump right into CNC whether it be at home, which I just don't get, or for work. As far as work goes the only ones making decent money are programmers, and that can be outsourced either within the conus or outside. Programming literally went the way of IT.
Jumping into CNC for home use in my opinion will be expensive and frustrating. The up front cost will be expensive and without having manual experience you're going to burn up a lot of tooling before getting proficient in knowing what your machine will do and listening to what the machine and tooling is telling you.
Not that its impossible, but I see people equating it to 3D printing and from a cost standpoint its anything but.
Now, as far as that dull endmill goes, and plunge cutting, you can touch up an endmill in a pinch just like you can touch up a drill. Sharpening the flutes? No.
Touching up the tips/end so you can plunge? That is certainly doable.
As far as skills go, I have been in Tool&die for 35yrs and I'm still learning every day.
That being said its crazy that you've been doing it for 35 years and there's still more to learn. Thats another thing I love about machining.
Touching up an endmill? Lol I still have trouble getting a decent grind on drill bits I don't know if I would attempt an endmill at this point it's tough being self-taught with everything. Youtube has helped immensely, although there's only so much you can learn without doing. At least for me.
so then, slow the feed down, and 4 flutes will unload the chip .. same with band saws blades, and tablesaw blades, and metal cutting slot cutters. less teeth = more space for chips, more teeth slow the feed down to clear the chips.chip clearance is much better for 2-3 flutes, so you're less likely to get chips packing the flutes or recutting the chips. One reason why 3 flutes cut slots better is that there is only one flute cutting at a time (in theory). With 2 or 4 flutes, two flutes are cutting at the same time so if one flute rubs instead of cuts it pushes the other flute deeper into the material. To be honest I've never managed to get a good finish with 2 flutes unless it's carbide and I'm running it as fast as I can.
