I like this idea... I will have air next to the lathe... I could use a butterfly air wrench... and avoid the additional cost of going with something like the Atlas
I saw this while searching the forum... Cool idea...
New 5C Collet Chuck for My PM1340GT
I just added a Bison Set-Tru 5C Collet Chuck to my PM1340GT. As some have noted in past threads, the included key is a pain as it takes many revolutions to pull in the collet. Having seen MKSJ's post where he built a speed key for his chuck, I decided to do something similar. I purchased an...www.hobby-machinist.com
I saw what you are also using in that thread...
As I write this and continue to search and read the feedback... I think that I am coming back to grips with reality... for a newbie that is just playing... spending over 1.5K on the Atlas is not justified...
Leaving the Atlas out... my question then is, should I spend the additional $$ on the Bison??? Or should I stick with the original plan and order the PM. That thread where @Ischgl99 tore down his, got me a bit worried on spending 350.00 for the PM only to have to buy another/better one later... Maybe I am worrying for nothing.
With either option I will look at using one of those speed wrenches for installing and removing the collects... Air impact gun might be too drastic.
Yep I didn't mention my jacobs flex Collets, there my favoriteI had them all as well and sold them all other than a few Jacobs flex collet chucks . They work for what I need to do .
Yes, agreed. I will just get that handle... that should be enough improvement without going with an electric or air tool.An air powered wrench might be too much unless you can set (limit) the torque on it.
The 5C collets can be a bit of a tight fit, so they may need a little jiggling to start the threading. Using a power drive could damage the thread and may overdrive the tension unless the clutch is accurately set. Might be handy for removing collets, and the standard T-handle would be a real PTA. We each have our preferences depending on the type of work we do. I like the Bison 5C set-tru, but if on a budget I would not hesitate to get the PM version. If you have any issues they will address it. At the time I purchased my Bison 5C, I had already gone through two non set-tru 5C and one cheaper Chinese 5C set-tru. The first two were returned because they had bad TIR, the set-tru was OK but I had to turn the body true and the mechanism was sloppy. I have seen/used the PM 5C and it is better than the Chinese versions I had, I use my 5C about 50% of the time so for me it was worth the purchase price which was $900 with the back plate. Also when using your 5C I put a little bit of way oils on the the threads, but keep it away from the clamping surfaces.
Given that you can get the Bison 5" Set-Tru with a D1-4 back plate for ~$750 (best price I have seen), it is a hard decision.
Bison 5C Collet Chuck Steel Body, 5" SET-TRU
Bison 5C Collet Chuck Steel Body, 5" SET-TRU. Ships in One Business Day. Buy it and Save at GlobalIndustrial.comwww.globalindustrial.comBison Back Plate, D Taper for SET-TRU Chucks, 5" D1-4
Bison Back Plate, D Taper for SET-TRU Chucks, 5" D1-4. Usually ships in2 days. Buy it and Save at GlobalIndustrial.comwww.globalindustrial.com
D1-5 adapter is a bit more.
Bison Set Tru D1-5 Adapter Plate 7-875-055 for 5" Chucks
Bison Set Tru D1-5 Adapter Plate 7-875-055 for 5" Chuckswww.smalltools.com
Ohhh.... Thank you! I did not pay attention to that detail!!You do not want a direct mount, I recommend a Set-Tru where you have about +/- 0.005" adjustment to true up the center line of the chuck. I index my chuck to the spindle mounting position, it repeats within a few ten thousandth's.
