- Feb 8, 2014
- 11,144
It isn't as stable as cutting normally so a little caution is warranted, but it works well. You still need a small counter bore to have clearance for the tool, but that should cause no problems.
...the tool crashed into the piece then broke so the tip embedded in your chest, meanwhile, the part got out of balance, causing the lathe to shake violently and tip over onto you, then when your wife heard your screams and came to help, just as she reaches you, the motor shorts 220V to the frame, killing both you and your wife. a week later, the dog is dead because it hasn't been fed.
Please explain this.
