- Oct 29, 2012
- 1,328
Please explain this.You don't buy them, you make them. Take any 1/4" wide wheel and dress the end to a 60* angle using a diamond dresser.
Thread grinding on a mill? I don't recommend that......
I considered that, but it seems to me that if you can so easily form the grinding wheel, the grinding wheel will quickly unform itself when you start using it. So I was looking for a diamond brazed type wheel that doesn't wear away (as much).You don't buy them, you make them. Take any 1/4" wide wheel and dress the end to a 60* angle using a diamond dresser.
No my plans are for the lathe. A tool post grinder angled to the thread pitch.Thread grinding on a mill? I don't recommend that......
Are these unobtainium for the hobbyist? I can't find them for sale anywhere.Norton Abrasives makes excellent grinding wheels for this application, start there.
http://www.nortonindustrial.com/Thread-Grinding.aspx
Can we keep this discussion limited only to the things that I want to hear, and leave the dream crushing realities to people with realistic goals please? Sheesh.Thread grinding is a very specialised process and it is not recommended for DIY's.
Norton makes diamond thread grinding wheels, search for Norton Paradigm thread grinding. You are not likely to find pricing listed online as this is a very specialized field, you will most likely have to contact a vendor and describe what material, thread form, pitch, grinding machinery that you are planing to use and number of parts required from said tool, this will not be inexpensive.I considered that, but it seems to me that if you can so easily form the grinding wheel, the grinding wheel will quickly unform itself when you start using it. So I was looking for a diamond brazed type wheel that doesn't wear away (as much).
