- Dec 20, 2021
- 868
It's pretty slow, and messy. But it's worked for stuff I've when I've needed it to.Vegetable oil, hugh. Never thought of it. Works ok?
Quench speed needed is usually related to alloy content. Plain carbon needs to cool fast. 440C can air cool and will harden. O1, being oil cooled is in the middle of the road. A2, should be an air cooled steel. (A2 has about 5% more Chrome, and some Moly. i.e. more alloy = slower quench needed).
The trouble you're running into is the thick cross section. As the outside cools, is shrinks faster than the inside, which is building up wicked internal stresses. Thinking about this last night, for the base you could try an alumimum plate quench. That is, use two big chunks of alumimum fly cut flat, and drop the samples between them, push them together, and let it all cool. It works wonders on thin knife blades and other parts you don't want to warp.
The 416 is lower carbon, but is martensitic. At 14% chrome it's going to be more 'stainless' than the A2. Although, it's not 'stainless' like 304 or other austenitic steels. It won't get super hard, maybe 35HRC.
Dan
