- Oct 13, 2014
- 6,703
You're welcome,Thank you. Thats info that is more useful. I know I can add a DRO later. I didn't realize that it had all the features you listed. I didn't notice it had a powered cross feed. The tool post I did notice, but again, thats not a $400 dollar upgrade. As for the variable speed, I seem to remember reading that the variable speed motors are sometimes not as good? I can't quite remember what it was. But I think it had something to do with being better off just upgrading to a higer end 3 phase motor with a VFD or something like that.
But you have given me a lot to think about. I do like idea of having a powered cross slide. Just out of curiosity, how useful is that feature?
The variable speed, three phase motor VFD combo is a good way of achieving variable speed control for a machine that didn't already have it. However, I don't recall reading about anyone removing factory installed VS system and replacing it.
Power cross-feed can be used for parting off and giving fine finishes on facing operations. Also, if you do get a milling attachment, you'll have a power feed for milling!
What did you end up getting? After areading all the posts on here, I am now leaning towards the PM-1030V. The QCTP is around $200, and then the variable speed also. That makes up for the $400.
http://www.precisionmatthews.com/shop/pm-1022v-pm-1030v/
I selected the 1030V, then the addons I selected, The Stand, The drill chuck for the tailstock, The AXA master turning/boring set, and the 1/2" internal/external threading set.
Any other tools you would recommend?
I like the idea of using magnetic calipers for a temp, dro solution. I know I will need some center drills. Also Some cutoff tools. Cutting oil too. Can't think of anything else right now.
Now your talking! Good choice and smart to upgrade to the 30" bed, length will likely be more valuable than turning diameter for the work you described. Sounds like you will have enough lathe tools to get started. You will also need calipers and or a micrometer. A dial indicator with magnetic base is helpful too. Oh, and some steel and aluminum bar stock.... and.....
