- Apr 30, 2015
- 11,334
I like the name "Kicking Horse"- were they trying to sound like "Kicking A$$" ?
Also, isn't that a character in "Joe Dirt"?
duh, I didn't see it in the original post, lol.Yes, 3/8"
lol, yea it did remind me of that movie. The character's nickname was definitely something like that.I like the name "Kicking Horse"- were they trying to sound like "Kicking A$$" ?
Kicking Wing. Joe Dirt is a classic!I like the name "Kicking Horse"- were they trying to sound like "Kicking A$$" ?
What you have is some scrap hot rolled mild steel. It appears at some time, it had been painted reddish.Unless you've done a spark test, or some other kind of test, to determine that it is actually some kind of cast iron and not regular, mild, low-carbon steel, you can use any standard steel rod to weld it since it is most likely regular ol' mild steel that has been painted for corrosion resistance. When I say "any standard steel rod", I mean E6011, E6013, E7014, E7018 being the most common ones. Most welders under $500 can't run E6010s properly, so I don't recommend you waste your money buying those. I have two super cheap inverter stick welders, is how I know.
By the way, are you aware of the short comings of the stick welder (and it's accessories) you just bought?
Ah yes, that's it. I'm half-tempted to buy that little lunchbox welder, but I already have too many lunchboxes as it is!Kicking Wing. Joe Dirt is a classic!
That is not my steel, but I do agree with you on Yeswelders.What you have is some scrap hot rolled mild steel. It appears at some time, it had been painted reddish.
The welder you bought appears to be an Amazon prime day clearance of some kind. YesWelder's web site does not show this as a model? In general YesWelder's stuff gets mixed reviews. Many newbie posts happy to have gotten the welder, several disappointed experienced welders. I'm guessing you paid close to $100 for this thing? If it works once...
Users complain that YesWelder will not provide service to anyone who bought their welder off Amazon. I'm guessing this means some entrepreneur bought out a lot of substandard welders and blew them out on Prime Day?
The usual rule that a man that buys cheap tools may apply here. You'd have been better off buying a Harbor Fright Titanium stick welder, at least there are reviews that show they work.
Now on to your project:
Pretty much the most common rod to use on mild steel is 6013. I'd suggest you start by practicing on some scrap. Be sure you clean the paint off b4 you weld. The steel you have looks a bit light, is it 10ga? Try welding at 100amps then. Be sure to brace the frame on the diagonals as the thin stock will flex too much otherwise.
Post photos of the result!
Astrobuf
While that may be true, they do make E6013 up to 3/16" diameter. One of those at 225A will do plenty of damage, sheet metal or not, to that ⅜" angle steel.POint of information
6013 is designed to weld NEW sheetmetal
3/8” is beyond that
6011 root passes, 7014 or 7018 caps
