When i originally spec'd out $1500, it was meant as a rough guideline. there are a lot of very capable import lathes in that price range. Lathemaster's 8x14, Harbor Freight's 8x12, Grizzly's 10x22, Busy Bee's 10x18 and any of the 9x20's. All of them have some standout features and all of them have some areas for improvement. i honestly haven't run each and every one of those machines, but i did do a ton of research. product reviews, forums, spec sheets, owner mods, historical websites... you name it, i dug through it, including everything that i could find on the vintage american iron, since a lot of the used machinery falls into this price range. the one thing that i noticed was that each had shortcomings. a lot of which would not be that difficult or expensive to modify if it was a fresh build. with the exception of another pound of cast iron a little different mold and another couple passes of the surface grinder, adding another v-way is not a big deal. increasing the size of a spindle and subsequent larger bearings (to have a larger spindle bore) is also a relatively inexpensive improvement when done at the manufacturing level.
so, that's what the point is here. to see what we can come up with that has the least amount of shortcomings, the best value in it's class, the broadest amount of usefulness and would hopefully be obtainable to a person who might not have the opportunity or the funds to ever buy another lathe. i would like to see something that isn't looked upon by professional machinists as a toy, but as a viable piece of machinery that just happens to be available to anyone, something that's easily up-gradable, eminently rebuildable and just plain fun to use.
to keep the price down may mean starting with a "base" model, just a high quality bare bones manual machine. Instead of starting with a base model and figuring out how to upgrade it, we're starting with the upgraded model and we can turn it in to a "chopper" for lack of a better term. just what's needed to run and nothing else if need be. as an example: the machine might not be CNC out the door, but there's no reason that the mounting bosses for stepper motors or pulley's behind quick-release hand wheels couldn't already be there...
this started as mainly a thought exercise, a "what if" scenario to get people thinking and dreaming... who know's, it may end there or it may take on a life of it's own and we may be seeing these for sale in the next couple of years... either way, i'm enjoying it!
