- Mar 25, 2013
- 4,643
I don't believe the strength of the alloy is an issue here as Bob suggests. 2024 with not be very corrosion resistant and will turn gray over time. Personally, I have stopped using it entirely. If this part needs to look good, 6061 or 7075 would be good choices. It is in contact with steel, but I think dissimilar metal corrosion is only a major issue when you throw in water. Ask me how I know...I just had to cut a homemade rack off my truck with an angle grinder because the SS bolts were welded by corrosion to the 6061 parts!
R
R
