- Jul 2, 2014
- 7,594
Threads bearing a load on the inside of a bushing is always a bad idea, shear and double shear applications should have the full fastener diameter (not threads) working in the shear area. Grade 8 has nothing to do with it, that would just be a poor design. I thought perhaps you were spreading the old wives tale that grade 8 bolts are "brittle," which they are not...Bob, this has nothing to do with strength specifications, that's a different ball of wax. This is about thread design, specificly the grip length. Using a standard grade x bolt in this application will result in threads being pressed into the internal bore of both the spacer and the frame bobbin.This application requires a bolt that has a thread length designed to work with a double-shear application.
