- Jun 17, 2011
- 2,062
I have a cheapy import and a Miller elite. I've found that different helmets use different conditions to trigger them. The cheapy reacts to flickering infared light. The TV remote will actually darker it, as will an incandescent light bulb on AC. The only time it doesn't stay dark is if I get a very steady arc on a DC TIG. I added a light bulb that is switched with the current sensor I made for my first TIG setup. The bulb keeps the helmet dark even if I'm doing a perfect TIG arc.
The Elite uses some more complex conditions. It doesn't react to light bulbs. Sometimes, if I'm welding outdoors, it will hesitate to darken. There are more adjustments than on the simple one and I'm sure I could tweak is for better response.
Both are good helmets. I'll keep both on the job.
