Hello all, and a Happy New Year to you...
I have some further progress to report. After taking the cone pulley out of the electrolysis tank and cleaning it up, I noticed that the bronze bushing at the gear end is actually the gear and bushing all in one. Yes, the gear is bronze, and integral to the bushing. It must be a press fit into the cast iron bore and then it is pinned to the pulley. The other bore beside the bull gear is in the cast iron of the cone pulley. No bronze bushing there.
Here's a few pics after cleanup...
I then oiled the bores and spindle to see if it would go back on. It went into the cast iron bore with a very nice sliding and spinning fit, but would just barely begin to go into the bronze bushing and then suddenly stop and jam. I then tried to slide the spindle into the bronze gear end, and it would slide in and spin nicely, but only to a depth of about one inch. This is, coincidentally, the depth of the gear. Puzzled, I then decided to get out some measuring tools and see what was going on.
The spindle bearing surfaces were consistent to withing 2 tenths at all sides to 2.4982. The cast iron bore was consistent throughout at 2.5001. The bronze bushing bore was right at 2.5001 within the gear, but then became smaller to 2.4957 and then at the bottom, it was 2.4949. So it was about .005" too small. No wonder it took 15 tons of pressure to pop the cone pulley off the spindle.
This lathe has all of the signs of having spent some time outdoors in the weather, so I believe that there must have been water, laying inside the cone pulley in the reservoir between the bores. This then resulted in rust forming between the bronze bushing and the cast iron bore, causing the bronze bore to contract, and then becoming stuck to the spindle.
So, last evening, I decided to see if I could mount the cone pulley in my Colchester lathe and rebore the bushing.
Here's what I came up with ...
I took my time and ended up getting the bronze bore right on size...
Before removing the cone pulley from the setup, I took the spindle to the work and did a trial fit. It was spot on. Here's the cone pulley back on the spindle with a lovely feel to the spinning fit.
Shortly, I will head down to the shop to take the cone pulley off the spindle and press the bull gear on. Then I'll put the cone pulley back on and continue building the spindle and putting it back into the headstock.
Brian
