... I'm pretty sure those class 3 are NOT the precision bearings used in machine tools. Class 3 actually are used in automotive applications the Amazon description even mentions it. ...
IIRC, you need Class 1 bearings, possibly Class 2. Most likely special order. ...
Not my first Timken bearing rodeo, my friend.
I'm not sure about the bearing numbers used in a No. 6/12 spindle, but the bearing numbers in a 12/16 spindle are used in lots of truck axles. Maybe that's what they're talking about.
The Timken bearing class number use the ABMA (American Bearing Manufacturer's Association) rating scale. Classes 4 and 2 are "standard" classes. Classes 3, 0, and 00 are "precision" classes. Timken also has a class 000 grade of bearings (at least on paper). The standard bearings don't have the class number marked on them.
Class 4 bearings have a 0.00200" maximum runout and are used for wheel bearings.
Class 2 bearings have a 0.00150" maximum runout and are used for gearboxes.
Class 3 bearings have a 0.00030" maximum runout.
Class 0 bearings have a 0.00015" maximum runout.
Class 000 bearings have 0.00004" max runout.
Note that there is no such thing as a class 1 bearing (at least in Timkin) and that class 3 precision bearings have a fifth the runout of class 2 standard bearings.
Here's a link the the Timken Tapered Roller Bearing Catalog. The runout specs are on page 29.
http://www.timken.com/EN-US/products/Documents/Timken-Tapered-Roller-Bearing-Catalog.pdf
Good luck finding anything better than Class 3 except as old stock.
A standard grade bearing cup and cone will run you about $20 vs $200 for the same bearing in class 3. IRRC, the quote was over $1000 for a class 0 matched cup and cone, and that's with a 6 to 9 month wait. Imagine what a class 000 set would cost...
Cal
