My friend Duane stopped over once again this morning armed with a bag of test devises and other tools of the trade. He solved the problem but we're still kind of confused as to why the machine was set up the way it was. Basically the whole control panel was set up to run on low voltage but the motors were wired for high voltage. The reason I couldn't get it to run on 220v after changing the motor over to low voltage was because the voltage at start up when fed from my 5hp rpc was too low for the transformers in the control panel. It caused the relays to chatter and drop out. Duane once again wired a 110v extension cord to the control panel to power everything except the motor starters and motor which were powered by the rpc. That allowed the relays to hold and the motor ran perfectly. I still can't run in high speeds but only because I don't have enough power to do it. If I had a 10hp rpc I'm pretty sure it would do everything it's supposed to do. For now I'm going to mount a seperate box for a 110v circuit to power the controls and use the rpc I have to run the motor. Duane seems to believe that now that he understands what was going on he could probably power it with his 7 1/2 hp vfd and get it to run in high gear. Now all I have to do is decide where I'm going to put the machine, finish wiring it, and get it leveled up so I can take some true test cuts with it. Thanks for all the help.
Chuck
Chuck
