I have been trying to power my Polamco TUM 35 geared head lathe. I have tried my existing 5hp rotary phase converter. Its a panel I bought from a supplier on Ebay hooked up to a 5hp idler motor. It has worked well for me for a few years. The lathe has a 5hp motor. The rpc would power it ok in lower speeds, but when I tried to start it in the 1250 rpm range it wouldn't spin up to speed. Actually it was kind of slow getting to speed at 900 rpm. I next tried using the 5hp rpc that came with the lathe. This unit seemed to be heavy duty. The company that manufactured it is still in business in MN. I called and talked with a tech there before trying it and he told me it probably wouldn't turn a 5hp geared head lathe at high rpm. He suggested a 7 1/2 hp unit at a minimum. I did try it and it worked better then the one I had but wouldn't even begin to spin it up @ 2500 rpm. Tonight a friend stopped by with a mitsibishi vfd. I don't know how many amps it was rated for but he told me it was a 7 1/2 hp unit. Model 100 I think. He wired the control side of the box to a 110v circuit and used the inverter to power the motor. It wouldn't spin it at 1250 rpm. It would start turning slow, after about 15 seconds it would just shut down. The amperage never went above about 4 amps. It worked fine at lower speeds. He mentioned that I might be able to power it with a constant torque vfd. Realistically I don't need the higher rpm ranges for my use, but it's going to eating at me just knowing that I don't have it powered correctly. Has anyone had problems similar to this with a geared head lathe? I don't believe there is anything mechanically wrong with the gearbox that would cause extra drag on the motor. It just runs too smooth to have a bad bearing or gear in it. Any suggestions would be appreciated. Thanks
Chuck
Chuck
