Yes there are always fakes at a lower price, but not really accurate, the VFD's for HY are sold factory direct on Amazon "Sold by Huanyang Electrical". Read the reviews, they are pretty dismal. I just replaced one that died on a friends lathe and switched it out to a GS20. Replacement worked like a charm, and now the lathe actually can brake to a stop. At the end of the day you can believe what you want.Turns out there are fake Huanyang vfds out there. Less capacitance, no current sensors, less robust components. I wonder if the complaints are on fakes....
4 stars on the one I'm looking at. Pretty bad.Yes there are always fakes at a lower price, but not really accurate, the VFD's for HY are sold factory direct on Amazon "Sold by Huanyang Electrical". Read the reviews, they are pretty dismal. I just replaced one that died on a friends lathe and switched it out to a GS20. Replacement worked like a charm, and now the lathe actually can brake to a stop. At the end of the day you can believe what you want.
Amazon.com: Customer reviews: HUANYANG Vector VFD Variable Frequency Drive,220v-1 or 3 Phase Input, 220V-3 Phase Output, 5.5kW 7.5HP for Motor Speed Control,GT Series
Find helpful customer reviews and review ratings for HUANYANG Vector VFD Variable Frequency Drive,220v-1 or 3 Phase Input, 220V-3 Phase Output, 5.5kW 7.5HP for Motor Speed Control,GT Series at Amazon.com. Read honest and unbiased product reviews from our users.www.amazon.com
The 12-2 and 10-2 wire arrived. I think I have a plug so I can disconnect the vfd for service. The 12-2 will be nice to have for additional 120v outlets. Especially for my saws.4 stars on the one I'm looking at. Pretty bad.
I saw two videos that detail the differences. You are strangely desperate that I spend more money than I have for this project. I'm looking at the GT series for a small increase in cost. Apparently they give more torque at low speed.
The vfd I'm looking at will start up without exceeding fla and runs off single phase without the requirement to supply double the single phase amps of the 3 phase fla.Just a thought, my Hitachi WJ-200-022SF VFD drives my PM1440GT 3HP motor just fine. Hitachi rates this as a 2.2KW VFD. This maybe considerably cheaper than getting a bigger VFD. Probably the greatest load that lathe motor sees is on startup (huge chuck, gears, etc). Once things are all spinning the load (current draw) should be a lot less. However, unlike just turning on the power switch and having a huge surge of current into the motor windings, the VFD starts the motor up via an acceleration ramp with controlled current. Hence, the sudden start up torque/load should not be as bad.
