- Jul 28, 2017
- 2,376
The fact that the gib is pretty narrow might affect its rigidity, since the force from the gib screws won't be distributed quite as well. Before buying a cross slide I'd recommend buying or making a replacement gib. It will be a lot cheaper than a cross slide.Well I have had a few days to play with this thing and after shiming the vertical slide in both directions I couldn't get it any better than using no shims at all. The surface profile after shims only got worse. But I did get good results when I worked on cross slide. I tighten up the Gibbs and got (to me) exceptable results.
.0005 horizontal difference and .0008 vertical
difference BUT this thing is NO fun to crank!
I guess a total rebuild and refit of the cross slide is in order.
I have a extra cross slide that I dissected today
And found two obvious issues one being way to much back lash as stated by HomeBrew and the other issue was poor fitting gibbs.
They looked to me like they were at least 1/8" to narrow. As it stands now I don't know if fixing this one or buying a upgraded cross slide would be better?
My theory could be totally off, as well -- I have read of folks making gib strips out of plastic, which would be a lot more flexible than steel, with no problem. Still, it would be a less-expensive experiment.
