- Jun 7, 2013
- 10,122
The ball bearing is to take cutting forces, not to guide the blade; back off the chevron guides and adjust the upper wheel tilt so that the blade does not run against the ball bearings, with the saw stopped, adjust the chevron guides so that they barely touch the blade, then readjust the upper wheel tilt so the blade barely touches the FACE of the ball bearings while running.
