It's the age old question, and I don't know if it will every be answered. But I was wondering if it could be approached a different way...
It's the fear of every new hobbyist that, not knowing any better they drop a couple of grand on a used machine that is no good anymore, or that they spend the same couple of grand on a new machine that turns out to be too small for what they want to do. I'm talking about the $3-5,000 price range.
So, say you are considering a PM-833T or a PM-835S for a new mill vs a used Wells-Indes or Bridgeport in the same price range. something like one of these:
Assume you can do the normal things like make sure it turns on, sounds like it is running smoothly in all speed ranges, shake the table to see if it moves, check to see that it runs across it's full range of x,y and z axis's etc, but that you aren't able to spend more than say 5 or 10 minutes examining it. In other words, no one is going to buy a machine with obvious issues. But if it looks good, sounds good and seems to function well, how likely is it that it will have a serious issue? Is it more likely to perform worse, better or the same as the new but smaller machines?
What about the same basic question but for a PM-1340GT lathe vs something like these:
Is there a different level of concern with a lathe vs a Mill, or is it pretty much the same thing?
Webb Champ 10" x 50" Variable Speed Vertical Milling machine w/ DRO, Power Feed | The Equipment Hub
General Info: Stock #: SB-200010 Location: Stone Mountain, GA Brand: Webb Model: Champ Serial #: 6656 Year: 1990 Approx. Shipping Weight: 3,500 Lbs. Approx. Shipping Dimensions: 72″ L x 72″ W x 93″ H Skidding Fee: $200 Specifications: Table Size: 10″ x 50″ Longitudinal Travel (X-Axis): 36″ Cross...
www.theequipmenthub.com
Amada AM-103 Heavy Duty Vertical Milling Machine w/ 3-Axis DRO | The Equipment Hub
General Info: Stock #: CD-191040 Location: Stone Mountain, GA Brand: Amada Model: AM-103 Serial #: 16320198 Year: 1986 Approx. Shipping Weight: 4,200 Lbs. Approx. Shipping Dimensions: 75″ L x 75″ W x 91″ H Skidding Fee: $250 Specifications: Table Size: 11-13/16″ x 41-3/8″ Spindle Speeds (16): 70...
DoAll Romi 13-5 13" x 60" Engine Lathe | The Equipment Hub
General Info: Stock #: CD-191235 Location: Stone Mountain, GA Brand: DoAll Romi Model: 13-5 Serial #: 32869 Approx. Shipping Weight: 3,500 Lbs. Approx. Shipping Dimensions: 106″ L x 52″ W x 68″ H Skidding Fee: $250 Specifications: Swing Over Bed: 13″ Distance Between Centers: 60″ Spindle Speeds...
Tos Trencin SN 40B 16″ x 60″ Gap Bed Engine Lathe | The Equipment Hub
General Info: Stock #: CL-191027 Location: Stone Mountain, GA Brand: Tos Trencin Model: SN 40B Serial #: 040150811756 Approx. Shipping Weight: 4,000 Lbs. Approx. Shipping Dimensions: 124″ L x 44″ W x 64″ H Skidding Fee: Skidding Unavailable Specifications: Swing Over Bed: 16″ Distance Between...
