- Dec 26, 2015
- 2,079
I’d be using an annular cutter and cleaning up with boring bar. I can’t imagine trepaning that deep.
Congrats on completing it. Next time, read the fine manual RTFM.Pretty much done.
Have you ever done anything stupid?
I was reading through the instructions and what should I find?
”””, The 4.25” OD head collar was made from a 3” threaded pipe coupling, simply boring out the internal threads to 3.75” will yield just the right sized material for the collar””.
You know, the one I spent half a morning boring out. !(note to self, read first)
This thing rocks! It’s very smooth and easy. My wife used it with a big smile on her pretty face .
Price of annular cutter that cuts about 2 inch deep 2.1/4 dia seems to be over 300 dollars. And if I remember I broke a few of them setting them up. I did not check price of bigger ones. But that would be costly for cutting 1 piece. Some where in my stash I have a brand new one around 3 inch dia. That I bought about 30 years ago. But you still have to have a lathe with lots of power.
Jimsehr
DaveSteel Dragon Tools® 2" x 2" Carbide Tip Annular Cutter 3/4" Weldon Shank | eBay
This bit will quickly and safely cut holes in steel. Weldon shank. Weldon Shank. Bit size is etched on each cutter. Pipe Tools. Pipe Drain Cleaners. Machine-finish hole with no reaming needed when using lubricant.tinyurl.com
Works fine on my PM1340 with power to spare provided the tailstock is properly aligned.
Pretty much done.
It's David - Dave is my dad. I have carbide tipped annular cutters in 1.0, 1.5, 2.0, and 2.375". Each one I purchased for use on a single job for about $70, but have found them useful on many other jobs that have come up downstream. Being able to slug out a large diameter hole in material as a first step toward a larger boring operation (on either the lathe or mill) is a very common occurrence - at least in my shop. This is where an annular cutter saves a lot of time and wasted material. I don't own a 3" annular cutter because they are too expensive. So if I were needing a 3" diameter hole, I would use the 2.375" annular cutter, be rewarded with a slug I could use on some other project, then I would bore to the finished diameter. That's a lot less time and wasted material than using a small diameter twist drill and boring from there. But to each their own.Dave
Have you checked cost of annular cutter to cut over 3 inch dia part? Even if you have no problem cutting with it? For 1 part?
