- May 4, 2015
- 3,583
If the mill has the nod option then adjust it on the table in front to back and side to side. With the arc of the indicator to the edge front to back . If your mill doesn't have the nod then you'll need shims and have to shim the back of the mill mount to the base . It's tricky can be done. Stefan Gottswinter, on YouTube used an epoxy to cure his mill problems . He's very very good as a machinist .
