- May 7, 2023
- 1,415
Any and everything you do comes down to the person doing the work, not the specific tool.That's blasphemous. Off to the gallows.
Yes I know the types, seen dozens of them that couldn't function without their #### tool, and I've seen guys that would mess up with the most sophisticated measuring tool known to man.
I even scribe lines with a pair of calipers. Those are my 2nd order pair I keep in the garage for the mice to use, but still.
Dial calipers got the name "Guessing sticks" as there is no backlash springs to keep the gear train in tension and engaged at all times like an indicator has. Digitals eliminate that and are much like having a hand held DRO.
The longer you do the work the more you realize the theory of diminishing returns, otherwise known as the 80-20 rule or Pareto principle.
