- Nov 14, 2016
- 3,007
Great info, but still all very daunting. Is the auto settings one any of these machines at all useful besides the Miller? i could see a good auto being as useful as a memory in that it would be a good starting place.
I don't know, as most of my info is dated a few years since I bought in 2019. Esab and Lincoln both had similar features, but different... Hard to explain except to say the Miller Autoset seemed more tuned towards inexperienced welders. Lincoln and Esab more a convenience feature. In reality all the Miller Autoset is, is the recommended settings you would get flipping through the manual.
Inverter machines are very new technology. My older welding text book was written in 2011 and only made brief mention of invertor machines. I had to upgrade to the most recent edition for class and there is now a large section on invertor machines. All welders are benefitting from invertor technology, but TIG seems to be the process which is gaining the most from it. MIG and stick it is largely a size / weight thing, but the new TIG machines can do things that were simply not possible with the old transformer technology.
I'm not a professional welder. I don't even play on on TV! lol.
In my (limited) experience, when learning to weld you are better off learning what each of the settings are and what they do. That is, it's more helpful long term to learn about the welding process and the appropriate settings than just hit a button and strike up and arc, then and see what happens. Auto settings might be nice, but once you have a feel for welding you're probably going to be tweaking them anyway.
I always knew welding was a skill. But after learning some, I have a lot more appreciation for what it takes to make a good weld. There are no shortcuts.
Dan
I like the autoset because it doesn't hide what the machine is doing, you see exactly how it is set, and can adjust from there to tweak the arc to your preferred settings. It is not a black box or arbitrary number as you see with some cheaper welders.
It is really not much different from flipping through the manual to see how to set the machine up for your weld, it just lets you skip the flipping through the manual part so you can get right to work. If you weld everyday or at least every week you probably wouldn't get a lot from it, but when you are like me and weld a couple times a year it is a very nice feature and lets me get right to the welding instead of having to recall how many amps per .01" of metal (and hope I remember right) or consulting charts (after I remember where I left them).
