- Nov 26, 2017
- 1,517
OK - for us beginners, I take it that means changing the wire spools is a right Royal pain!
Sufficient to motivate buying a whole other welder!
Thus perhaps suggest the generally most useful size. I get it that if you want to weld car body sheet metal together in a butt joint stitched weld, you will likely need the thinnest.
What suits 2mm wall angle or box?
What about 3mm thick 40mmx 40mm angle?
What goes with 6mm (or 1/4 inch) 2"x 2"
Suppose you have a "thick" weld to make, say approx 10mm (0.4"), and you have it beveled, and a root butt, and you want to do a multi-pass
What spool size?
Also, while we are at it, how to stop it curling up together as if to close the joint.
Is this kind better done as a stick weld?
Changing wire is not difficult at all. Cut the wire, pull the spool, pull the wire out of the gun lead, insert new wire sppol. loosen the drive tension, push the wire through, push button for cold feed, adjust tension and close the door.
I have only had an issue when the gun feed sleeves start to wear out and need to be replaced.
