Thank you so much manIf you're interested in doctoring up a cheap set (which does work, it's just time....), here's a quick video that will show you what the problems are, where the springs shoot out from, and how to get them back together again.
I have bought a cheap (20 $) telescopic gauge set some years ago. I compared them to my inner micrometers for a month. After a few days (learning period), they produced the same results.
I do not measure the size on the telescopic gauge because it seems that the force of the micrometer (0.5 mm pitch) is to much for my telescopic gauges. I now set the micrometer to the requested size and feel how the telescopic gauge fits. I also measure twice, pickup the size using the gauge and measure the gauge using the micrometer, to be sure.
It’s like cheap adjustable parallels: they are accurate, but the dovetails are full of grinding dust - take them apart, clean, lightly lube and they’re great.This is whats nice about the quality brands , I hate some second hand mitutoyo ones and they repeat on measurement to better than 0.001"
Some of the cheaper ones can probably be finessed to good working order but I have had very very cheep ones where the machining of them was beyond saving.
Stu
Better. Easier to check taper & out of round. Smallest bore measureable is 50 mm or 2” though. Buy both types.I found this one from china, how does this one compares to the telescopic gauge.
[US$44.99 17% OFF] 50-160mm/0.01mm Metric Dial Bore Gauge Cylinder Internal Small Inside Measuring Gage Test Hand Tools from Tools on banggood.com
50-160mm/0.01mm Metric Dial Bore Gauge Cylinder Internal Small Inside Measuring Gage Testm.banggood.com
I am looking for tools. I also have a b&s 420cc that needs a rebuild.
