- Mar 19, 2014
- 2,681
If this is your first try at cutting a “T” slot, then there are few cautions. The one big caution that comes to mind is, you MUST keep the chips clear from the T slot cutter. Or it will clog up and probably break the cutter or at least ruin the dimensions of the T slot. The second is, first make a pass with a regular end mill down the middle, cutting the middle section of the T slot to size. I cannot emphasize enough the first big caution…Dave.
