- Aug 22, 2012
- 4,114
I need to bore a narrow taper into an 8mm hole approx 25mm long.
I turned the taper that has to fit in it by setting the compound over.
I've kept that degree setting but now need to bore the internal taper.
What would be the easiest method when I do not have a boring bar that will fit in that hole.
