- Feb 1, 2015
- 9,605
It appears that there is a matching groove on the bottom of the tailstock, indicating that the particle causing the groove was trapped under the tailstock. From the depth of the grooves it was probably a harder material like an abrasive or chunk of cast iron. Did the the scratch occur after your receipt?
It also appears that there wasn't sufficient material to properly finish the bottom surface of the tailstock. Slight imperfections in a casting are acceptable. This appears to be significant. It should have been caught in in-process inspection. By the time the lathe is ready for final inspection, faults like that are seldom caught. My Grizzly lathe was supposedly inspected by Grizzly before shipping to me but it was securely packed in its shipping crate so their inspection most likely just confirmed, "yep, its a lathe".
I have seen many instance of manufacturing defects which would be classified as hidden defects once the article was assembled. There is a huge reliability on the production worker self inspecting. Past that, having adequate Q.C. systems in place is also an excellent practice. Unfortunately, profitability concerns often overide the quality concerns. It is the reason that many of our fellow machinists completely dissemble and clean a machine on receipt.
