- Nov 16, 2012
- 5,596
Paul,
You're absolutely correct... I failed to ask about RPMs probably thinking the OP had tried all speeds with no luck. With HSS, a piece about 1" should be spun at 400-500 RPM and with carbide, around 1000. You're right, a piece of mild steel is a tough customer. It certainly won't cut at low speeds and untuned lathes often start shaking when you get past 600 or so (depending on how heavy the unit is). I guess my mind gravitated to that line of thinking.
Ray
Ray
I have been following this thread for a bit and have not seen any comments on rpm. That piece looks under an inch in diameter so you may have too few rpms at 300 rpm. I had a piece in similar in size and spun it at 900 rpm to get a good cut. At this speed, I had no chatter to speak of and kept the cutting oil flowing to ensure a good finish.
Just be ready with a hook to pull away the swarf that builds up as this will catch between the tool and the work and give you a striated finish.
You have picked a notoriously difficult metal to machine to a good finish. Good luck.
Paul.
