Bernie,
Are you refering to the scratch like marks or the spirals that have a twist you can really only see them right at the top of the light reflection.(think barber pole stripes) they are not really a grove but more like a pattern of light chatter marks. I might just be looking to hard at them because they come out with 400 or even 600 grit paper. (and I mean in 3 or4 passes.) I think I just started getting a finish that was smooth enough to see this effect. The lathe may not have changed it may just be I am getting a cleaner cut using HSS a long with other thingsi have changed such as feed,spindel speed, and bit stick out. All things I picked up on here from all the great people. If you are looking at the spiral what is the fix to keep the chip behind the cutting edge? I think the bit was ground at 10deg. on both releifs with 10deg. end angle, 0 side angle and i do not recall side rake I think +8-10,
Thanks for your imfo, and help,
Mark
Hey Mark-
First of all- good problem to have, right? You are obviously getting better if your machine is the problem and not you! Seriously, that's great.
Ok- I have to say that I am having a hard time seeing which mark is spiral, and which are scratches from the pics. So +1 from me about closer pics.
****Pic Tip- you can put a magnifying glass in front of your phone or camera- just play with the distance from the workpiece, and camera to magnifying glass****
Looking at the pics, I WAS referring to irregular scratching.
But reading more of the thread here about your spiraling issues, I would start by saying to try to make the problem repeat, so you can scientifically rule things out.
Ray has most of possibilities nailed down for you. I will mention a few I haven't seen mentioned yet.
One- when you are running the lathe with the carriage feed, do you HEAR a "chugging" sound, or is the gear noise completely regular? If it is chugging, listen to Ray' suggestions, and also check that ALL the gear teeth on the feed gears are clean, and COMPLETELY. Free spinning. Or at least all smooth and the same all around.
Two- it looks from your pic like your machine has roller-spindle bearings. My suggestion is NOT as likely, but if your issue is the same whether in carriage feed or hand feed, you might have an issue with the cage in one of your spindle bearings, or with one of the balls/rollers. Not the most likely candidate. Or foreign matter in the bearing race. How do these bearings feel when the belt is loose? Is it completely smooth spinning by hand? Or jumpy or gritty?
Is there any way to measure if the irregularity is a deeper cut or raised up?
Hmmm.... Fun brain teaser!!
Three- Is the spiral almost exactly the same if you hand feed the carriage at somewhat irregular speeds, compared to feeding it really evenly, like you were trying to do?
Bernie
