I may try again in a different material today.
The insert is coated. It is Kenametal with a KCPK30 coating. Supposed to be used dry so I don't think that was the problem. It also has a T-Land edge. I tried another that had a honed T-Land edge with no difference. The radius is .039". I did try 900 rpm, appeared to be no difference. I agree I think it is a rigidity issue.
- KCPK30
- A multilayered TiN-TiCN-Al2O3-CVD-coated carbide grade with advanced Beyond™ post-coat treatment and a very tough substrate. KCPK30 has a wide application area in general and rough milling of steels and cast irons. It performs best dry but can also be used we
