- Aug 3, 2017
- 3
Oops, hit the send button by error.
Let me continue and complete my idea. No need to clamp to the column, just take your favorite drill press vise of any kind and attach some kind of bar to the left side of it. It can be some steel tubing, perhaps 1.5"x1.5". Just use whatever you have.
The bar should be long enough so that it touches the column when used anywhere on the table, and ifeally, it should stick out at least 4" to 6" on the operator side of the vice.
Hold your piece to drill in the vice. Position the vice for drilling the hole, all the while making sure that the bar is very close to the column or, ideally touches it.
That's it. Drill. If the bit catches, the piece and the whole vice assembly will spin a fraction of a degree for an instant and is immediately stopped by the column.
Problem solved. You can thank me later!
Here is my setup:
Here is my setup:
