Successfully welded cast iron
Braeden P
Sep 1, 2020
1,596
The “spacer” on the Y axis for the the lead screw on my planer was missing a good chunk and it would be a pain to remake. So I decided to attempt to weld it. I heated it up to cherry red, set my welder for 3/16” then dropped it down a volt. I basically did tack welds to avoid building up too much heat.(Better welds than a blind folded ape) Put it back in the furnace after about 30 seconds. Did this about 10 time then heated it up to a brighter red then let it cool to room temp over 6 hours. No cracks so I turned it back to what it was and it held up. I will fill the voids with a mix of JB weld and cast iron dust then paint it.IMG_6347.jpegIMG_6437.jpegIMG_6439.jpegIMG_6440.jpeg
Nice job! JB Weld already has iron powder in it so you may not need to add any filler.
JB weld has iron in it? I didn't think it did
Nice repair job! Looks very presentable
I checked the MSDS sheet and the original formulation contains 50% calcium carbonate (powered limestone). However, the back of the 10 oz. size tubes say epoxy steel resin and epoxy steel hardener.
