- Nov 27, 2012
- 7,858
Obviously you need to turn the AC plug around!
-brino
I was looking in the manual to see where the reverse switch is.
-brino
Will, Will, Will. (smh) You plugged the wrong end of the hose into the machine. Duh!
On second thought, you may have installed the new filter wrong side out.
Tom
I think that's the stuff you use to trim down Liquid Paper.I've often wondered how sharp cutting fluid is.
Does it draw blood if you spill it on your fingers?
