Sorry I don't have a picture that I can post, I'll try to describe it, basically you grind the drill so that it has a central spigot that will guide the drill as it cuts, and you grind the normal cutting edge down at a slight angle to be lower near the central guide and the outer corners contact the metal first the drill will resemble a traditional wood bit, but the central guide will not have the thread section on it. Sounds a bit odd. google grinding a drill bit to cut sheet metal. there a quite a few videos on you tube etc.
