I found the back gears.. I was able to get it to a lower speed.. I understand what you guys mean by using the second pulley on the shaft of the motor.. I will post some pics of the forward reverse on/off switch
I have.. its the original that came with the lathe.. new problem.. its seems as though the lathe is vibrating to the point that threading is bad.. and the threads I am cutting are all chopped up.. its not the tool
I can almost guarantee its the lathe.. maybe my gears are junky? or the surface in the garage is just uneven enough to be a problem... I did my best to make sure its sitting level.. but it seems to "bounce" so as to cause an issue with finish with turning and facing.. and Im using inserts that are new... I will post pics tomorrow.. thanks to all..
I am curious "vibrating / bounce gears junky?" Are you saying the lathe is not sitting flat on the floor? OK, jack up the right tailstock side in the middle of the two legs so it now sits on three legs, its now level. Try it. yes or no? With the belt on high better or worse. Better or worse running with no chuck?
Junky gears =they dont turn fast enough to be out of balance, i think the most gears can do, is to be noisy. Does it vibrate or bounce in back gears?
Mostly vibrations out of balance comes from something spinning fast not slow. bad threading, issues with finish turning, you sure its not chatter? As far as I know at least with my South Bends, they dont like inserts carbide all the new stuff. Kind of like putting high test gas in a Model T. It does no good at all. all I can say the lathe should run like a top. And its just the case of tracking it down like vibrations in a car will drive ya! For some reason I have allways played "second fiddle". Made short, a customer with 1 ton box truck (it went smooth as silk) but the driveshaft center bearing got a little loud, to he had that and a U joint replaced for $xxx bucks. Truck then shook like hell brought it back with no avail. Then it comes here to the problem child. Owner claims they just greased the origional bearing?? We took all apart, examined all and found "the big dollar rate shop" pressed the
center bearing probably with a big socket (on the outside race not on the press point) thus wrecking the bearing. So I charged him 25 bucks plus a
new bearing. Should of came here in the first place. Im trying to say, who knows what has been done to your lathe in the past. So you have to think like a animal MD. Doctor who are the smartest: Like animals and machines, the patients dont talk. With time and thought, you will figure it out. Just
remember it wasnt born with that condition. Please get back with some findings, I am curious, something simple I bet. Sam
