- May 26, 2015
- 762
Nope. The roll pins tapped snugly right in. I notice the tapered pins are soft metal and I figured they would sheer off instead of damaging a gear. The tapered pins are not proper as they only go in about half way.No. If the tapered pins are too long, you could always trim them off. Roll pins would require that the hole be drilled the same size the entire length.
