I'm glad that you finally got a top on your bench. You might want to put a lip all the way around the bench to help contain the chips (make the top an even larger chip tray).
Thanks. My metal folder (home made) will only fold 3mm aluminium at around 700mm wide so thats almost as wide as I could make the chip tray. I was contemplating making two of them with out being folded at one end and tig'ing them together to cover the whole table top....I may still do that.
I have a bit of a to do list which I want to work through as time and money becomes available.......
1, Make a remote switch box to control the lathe so I can mount the VFD out of the way. (switches etc are ordered)
2, Paint the Collet holder, steady rest and follower rest.
3, Buy or make some new hardware. The bolts that hold the gear box and apron in place are marred up a little as well as a lit of the set screws etc.
4, Align the tailstock. In fact check the alignment on the whole lathe. (I need to get some sort of aligning bar)
5, Buy a 4 jaw chuck and holder.
6, Set the gear train up correctly for Metric threading. (New 56t gear is on its way, I have the rest)
7, Replace all the felts etc
8, Replace headstock end washer with a thrust bearing of some sort.
9, Source some new oil cups from somewhere or make some.
10, Machine a better way to hold some of the gear train gears so they are not as loose and hopefully itll make the gears quieter.
11, Practice, practice and practice..........
Im sure there is more but thats the main list for this year..........
