- May 4, 2019
- 794
That could have been done with a hacksaw.
I would worry about the accuracy of a cut using a hand saw.That could have been done with a hacksaw.
Maybe making your own arbor for the slitting saw blade will help with the wobble. I had a similar problem with a cheap chinese arbor and I made a simple arbor that solved the problem.So I bought off of Amazon an R8 slitting saw arbor and a 1/16" saw blade. Although the saw easily went through the mild steel I did not like the cut. The blade "wobbled" so that instead of having a .063" slit it's much wider. I'm not happy with that. I believe it's from the accuracy of the cheap chinese arbor that's causing it and not the blade. Next, and I should have thought this all out, I discovered that the spindle and quill keep me from going down along side the part to make the other five slits I need. Unless there's some kind of extension for the R8 arbor I think I will not be able to continue with the slitting saw. Somebody mentioned earlier about the slit I'm making obvisously is a "thru" slit, which is true, although I'd prefer that it wasn't.
pics or it didn't happen.I did end up making my own arbor this morning. It actually came out perfect for my need. Those Amazon arbors are such junk.
