Maybe I should have mentioned the bottom side only.
Verzonden vanaf mijn iPhone met Tapatalk Pro
Me too. Also the spring pin that holds the offset cam to the shaft in the mechanism is too short. This means some of your energy is taken up from flexing and twisting. I sheared it off from bumping the handle forward to lock the tail stock in place. When I replaced it I used a longer spring pin. It helped, but under heavy drilling forces it still moves. If I take it apart again I'll use a solid tapered pin the next time.I have a similar problem on my pm1440
Yes that makes sense. It sounds like an interesting product. In a carbon bike frame, where clamping forces could be limited, help might be needed to hold tight enough as mentioned in this ad. On a lathe however it would be difficult to keep way oil from fouling the 'fibre-grip' on the plate.
http://www.finishlineusa.com/products/specialty-products/fiber-grip-
I have a similar problem on my pm1440 if there is any serious
tail stock pressure the tail stock slides on the ways. My plan is to remove the paint from the clamping ways and to machine the clamping surfaces of the bottom plate flat. If that fails I may increase the length of the clamping lever.
Sent from my SM-T550 using Tapatalk
