Only had 20 minutes today, but I think it may be bed/tailstock wear.
Long story short, I went to re-check the run-out of the live center before swapping in the dead center (I do have one), but my carriage wouldn't clear my tailstock to check run-out on the live center. The 0.004" of runout I measured the other day was on the collar of the test bar. I normally have the ram ~1/2" out from the tailstock, so to get clearance to check the center itself, I backed up the tailstock so the ram was out 1-5/8", and the tailstock was now back 1-1/8" on the bed from where it was before.
In the new position I saw < 0.001" of run-out on both the live center itself and the tailstock side collar of the alignment bar, and the tailstock was ~0.005" offset towards me. I re-adjusted the tailstock alignment, and now have < 0.001" of run-out on the live center and tailstock collar of the alignment bar, zero (or not measurable) run-out on the headstock collar of the alignment bar, and what looks like an aligned tailstock.
Bed wear or tailstock/ram wear?
I'll try taking some cuts as well as throwing my dial indicator on the headstock as Mike suggested in the morning...
