- Jan 22, 2011
- 8,031
Back up on Reply #22, there is a slight mistaken assumption. One that many folks make. When dealing with 2 different diameters in identical vee blocks, it is not correct to simply shim up the one with the smaller diameter by the difference in diameters. In the case of 90° vee blocks, a 0.2500" difference should have a 0.1768" shim. That is provided you want to shim straight up. It's simpler to shim each flank with 1/2 the diameter, saves the calculations. This is important if you are doing layout work, transferring points from different points along a shaft, or from one end to the other.
Not picking on anyone, just pointing it out.
