- Jun 27, 2016
- 378
Very nice! I have used Fusion for single items, but not assemblies as shown in your first picture. Is the assembly thing (join) hard to do?
Got any tutorials that you would recommend? I find that most of the presenters can't teach, they might know the program, but can't teach.
The Fusion 360 forum is good, I usually get quick responses to my questions.Thanks for that, but that is the one I didn't like at all.
Update #7
Today I started the re-assembly. This is the fun part for me, all the dirty work is done and you get to see it come back to life. The first step was to assemble to motor mount and install it. This actually took longer than I thought it would, this is a fairly complicated mechanism. There is a lever hand on the left side that allows the motor to easily raised and lowered. I think this was done to allow easy changes of the motor pulley. The original Vernon documentation indicates they supplied two different size motor pulleys to allow for different ranges of speed.
View attachment 435052View attachment 435053
Next I installed the counter shaft and then the spindle. The counter shaft is adjustable to set the tension on the belts from the counter shaft to the spindle shaft. I left the spindle bearings a little loose until they get some run time and warm up to allow final adjustment of the preload. I used some long 1/4-20 bolts to guide the bearing houses and some all-thread to pull everything in tight.
View attachment 435057View attachment 435060
With the upper belts in and the motor set I measured for the lower belt. With the mechanical speed adjustment removed the new drive belt from the motor to the counter shaft is fairly long, I hope it works ok.
View attachment 435056View attachment 435061
It is starting to look like a machine again. While I'm waiting for the new belt to arrive, I'll work on mounting the new electrical enclosure. I'd like to test the motor and spindle assembly before I get too far along with other components.
